I don't know where to start so this may get long - sorry. Please read below and ask any questions you think may need to be answered.
In the past week, I finally got the last components to finish my system (yes I know it's never finished). Over the weekend, I got my new rack and installed for the first time the following - Rotel RMB-1075 (5ch amp), Escient Fireball SE80(music server) and Panamax M5300-EX(power center) to my existing components - Denon AVR-2307CI, Cambridge Audio DV89, Motorola STB, Samsung TV and both SVS and HSU subs. Replaced components were a power strip and McIntosh MC2105 2ch amp.
OK, so I wired in all the cables, etc and confirmed that everything is working as it should, but never really had time to sit and REALLY test it, what with loading 250 CDs into the Escient, programming the Harmony remote and farting around with HP trying to get the S/PDIF function on the laptop working. Oh, and that pesky job that's got me working midnights 7 days a week right now.
OK, so I know there's a weak spot in the system. It's all plugged into a single outlet (more on that later, don't get ahead of me) So just now, I invited a neighbor over to check out the finished system and put in the Cannon fight in Master and Commander. I set the volume quite high. Cannons go off, but I don't feel anything so I'm like "Whoa neighbor, there's something wrong here." My first thought was of the power situation, which I didn't think was that bad because I ran the system off this circuit before with the MC2105 with no trouble and it sounded awesome.
So I ran an extension cord to a direct 15amp line in the kitchen and plugged in the SVS to that and turned off the HSU (and unplugged the audio cables daisy chained from the Denon out to SVS and out to HSU) to take some of the load off the circuit. Played the scene again and same disappointment. Plugged the SVS back into the wall (system circuit) and plugged the Denon and Rotel into the Kitchen circuit. No joy on that try either. Turned up the SVS past 50% gain (unheard of) and still no better bass.
I've had some trouble with HDMI on the Cambridge player, so I switched out the HDMI for DVI and coax. Still no better. I rechecked all my connections on the Denon preouts and they were all correct and tight. So now the Rotel and Denon are powered from the kitchen on a separate, dedicated circuit and the SVS, Cambridge and TV are the only things on the system's circuit and it sounds awful. No power is run through the Panamax. The SVS is clearly working but has no punch even at an un-Godly gain level and there's no crispness to the mains (like when the splinters and shrapnel from the cannonballs rattle through the ship).
Here's where it also gets weird. While testing out the power supply issues, the Denon, which normally has a master power setting at +8db decides that it won't go over +4.5db and it won't let me adjust the subwoofer level over +0.5db, which normally goes to +12db. I've found since installing the Rotel that I have to run the volume higher than I did when using the McIntosh and using the internal Denon amp for center and surrounds, so that didn't seem abnormal until the Denon suddenly removed these options. Some sort of system protection, perhaps?
The strangest thing I can't explain is that when I paused the player and turned up the volume, there was noise in all 5 speakers and both subs. It sounds like a strong winter wind blowing across a field, like a constant whistling, whoosh. I don't know exactly how to describe it, but with no source on, the subwoofer driver vibrates and all the other speakers have this "wind noise" when the volume is turned up.
Man, I thought I was done, but it's one step forward, two steps back. I can't even watch a movie loud. Oh, and loud music also sounds bad now too.
