Big time noob needs some advice for sound system setup
theproman23
I just purchased myself a Samsung UN55C6500 and love the darn thing.
The viewing distance is about 8 to 9 feet. The only thing I am not a big fan of is the sound from the TV.
Need some help setting up a sound system to go with the sweet tv.
I'd like to setup a receiver with at least 3 HDMI inputs and need some help picking out speakers to go with receiver suggested. I also watch a lot of movies and I am going to be hooking up my XBOX 360 as well. I would also like to be able to connect my IPOD to it and possibly even control but I think I am asking for too much.
Pyrrho
Pyrrho
You need to say how much you are willing to spend. There is no point in recommending speakers that cost thousands if you are only willing to pay a few hundred.
As for how it all will sound, the speakers (which includes the subwoofer) will matter more than anything else you buy. So if sound quality is what matters to you, spend the biggest part of your budget on speakers, and get a receiver that is adequate to your needs, but is not more expensive than it needs to be (unless you have money to burn). For brands of receivers, I would look at Yamaha, Denon, Marantz, and Pioneer (not necessarily in that order). For subwoofers, I would go with SVS, budget permitting. For the other speakers, you need to go out and listen to different brands, and different types (e.g., horns, domes, ribbons, etc.) that are in your price range. The reason is, there is no such thing as a perfect speaker, so you need to pick something whose vices are such that you can live with them. And if your budget is low, you will need to be more accepting of vices, but you still need to listen to different speakers, as the differences can be dramatic.
If you want to listen at volume levels loud enough to do permanent damage to your hearing, look for speakers that are efficient and capable of playing loud. That will generally involve horns. (I recommend that you don't listen at levels loud enough to damage your hearing, but that is up to you to decide.)
BoredSysAdmin
BoredSysAdmin
in addition your budget, you might want to add your room dimensions (including if it's open to other spaces) as It will greatly affect your choice of subwoofer and speakers
mpompey
mpompey
Most mid-range receivers will have 3-5 HDMI inputs that should support your needs in that arena. You can pick up a mid-range from Yamaha, Onkyo, Pioneer in the $500 range, maybe cheaper on Ebay.
