BIC DV62si Wall Mount Brackets?
blruggles
Dear Forum,
Am looking for recommendations for Wall Mount brackets to mount a pair of BIC DV62si speakers to the wall.
Would like something that swivels.
Hoping there is something out there reasonably priced. Also wanted something that keeps them a little ways from the wall so not to obstruct the port on the back. Thinking of using plywood on back with 2" Velcro to mount to the bracket and avoid drilling the cabinets.
Can anyone recommend?
Thank you in Advance.
Jack Hammer
Jack Hammer
Dear Forum,
Look into some Omnimounts. They fit most speakers predrilled threaded mount holes and are adjustable. They come in several different weight sizes and configurations and are reasonably priced online.
Jack
