audiointx
Does anyone know what the weight of this speaker is? I've got one on order and I'm looking for some mounting brackets for it. Thanks.
L
LOUMFSG
shipping weight is 26 lbs.
It is a pretty big speaker. You might want to check out the BT15 from B-Tech - holds 33 lbs. - it might work:
http://www.btech-usa.com/bt15.html
audiointx
That's what I was thinking of, but I just wanted to make sure the speaker was less than that.
L
LOUMFSG
Good luck
Let me know how that works out for you. I own the DV62CLR myself, and I've thought about mounting it (right now it sits under my display on a Salamander stand. By the way, I hope you enjoy your DV62CLR as much as I enjoy mine - it is a great center channel speaker
Shakatak
Hello All
For mounting large center channel speakers , I have seen people use and recommand T.V wall mounts that can be picked up at Home Depot or Lowes.
They hold a lot of weight, can be hidden behind the TV, close to the wall, the tilt up and down, move left to right.
Hope this is of some help.
