Bi-Polar or Direct Radiating for surrounds
Maximan
I have a friend who owes me some money.While I really do need the cash he made me an offer Im seriously considering.
I have a Def Tech set-up minus the rears.My friend knows someone with a pair of SM350's that he'll let me have for a 200.00 debt.How do direct radiating speakers work for rears in comparison to actual surround speakers??
I would have them on stands next to my sofa.The way the room is setup the speakers would be less than 3 feet from where someone would be sitting on either side of the sofa.
For those that use D.R. speakers for surrounds,let me know what you think.
chadnliz
Many use diect radiating instead of Di-pole speakers, some even run these diect speakers out of phase (reverse wires on speakers) to create the Di-pole sound, Di-pole surround speakers are wired out of phase from factory). I own B&W on wall surrounds that with a flick of a switch you can flip them in and out of Di-pole...........I strongly prefer Di-pole sound as it makes them sound much more diffuse and harder to localize, and that makes for the best experience..
I've used the SM450s for my surrounds. They worked great. It does not matter which type you use for surround speakers. The SM350s would work great. They are 57Hz-20kHz +/-3dB @ 90 dB w/m in anechoic chamber.
MDS
If the speakers are close to you, you will be able to tell exactly where the sound is coming from if you use monopoles (direct radiating). Bi/Dipoles create a more diffuse sound that is less easily localized.
As usual it is mostly personal preference.
