I have tried both bi-wiring and bi-amping my Jamo E855's and to be honest the differance is extreemly minimal if existant. I have many friends that work in Professional Audio shops and they said the only reason Bi-Amping or Bi-Wiring would increase the sound quality, is if your speakers have a poorly made or a low quality crossover.
As all bi-wiring does is makes it so the speaker's crossover doesnt have to split the same signal into two/three differant ranges. Hence 2-Way / 3-Way. Or the possiblity of high resistance speaker cable (which is unlikly unless you purchased Generic Cable).
However the best methods of deciding wether or not you think it makes a differance is to try it yourself!!!!!
I have decided i will list the differant methods of Bi-Wiring/Bi-Amping.
NB: Bi-Amping doesn't have to have differant receivers it can be done my using Output A & B on your receiver.
You also must consider that if your amp doesnt control Tone on both A & B speaker outputs (Not many do) then you have to decide wether you want to contol tone of your mid ranges, or tweeter. I leave my amp on direct or stereo with 0 Bass and 0 Treble i never change them. I normally connect Low ranges on A so you can control Bass Output.
The Simple Method:
Bi-Wiring:
Run two sets of wires from Left Terminals, and connect one to the low range and one to the hi range (dont forget to take out the bridges!!!)
Bi-Amping:
Concept of High and Low range coming from differant Amplifiers.
The "AudioPhile" method of Bi-XXXXing:
I have tested this method and i could notice a SLIGHT differance it has came recommended to me by a fair few people. Also known as the Xover Method.
Connect The left (Speaker A output) Negative to the negative terminal on the Low Range Terminals and Connect the Positive to the positive terminal on the High Range Terminal. Now with speaker B or the second amp. Connect the Negative to the negative terminal on the High Range, and connect the postive to the postive terminal on the low range.
This is expected to have a "blending effect" to make the speakers differant ranges not seem so seperated. It may work better for you guys that it did for me!!!
It has now came to my attention that the idea of Bi-Amping can often be confused. So It is not Bi-Amping through differant outputs. I will class it as a differant method of bi-wiring.
