Speakers are the most important factor in your system's sound. If you are trying to improve your sound, new speakers are where you should spend money, not amps. You don't need to spend anywhere near $2K for mains to get really good sound either... The Polks are easy to drive, so unless you are looking for deafening levels, an amp isn't going to "improve" them. Amps basically allow you to turn things up louder before you hear distortion; they will not make your speakers sound better than they are - this is a common misconception. Since you already have the amp, you would connect it to the preamp outputs from the receiver and then plug the speakers into the amp, but as mentioned, if you weren't hearing distortion already at the levels you listen at, the amp isn't going to help. When people say a speaker "opened up" with an amp, that is an indication they did not have sufficient amplifier power previously.
