Have you seen the Transformers movie? That'ts what I think about when I see the Custom One Pro Plus Headphones from Beyerdynamics.
Just like its successful predecessor, these versatile headphones offer maximum flexibility by combining quality sound with many individually adjustable parameters. You can use them for music listening at home of on the go, for gaming, for video recordings, for chatting, for podcasting... you name it!
According to the company, The Plus in the name stands for an extensive standard in design and comfort. These headphones feature what they call a Custom sound Slider which allows the user to adjust the sound pattern & bass level to your personal taste or to the music you are listening to. There are four different profiles to choose from, ranging from "Analytical" to “Heavy Bass“.
But the fun doesn't end here. As with other headphones from this company, the Custom One Pro Plus can be personalized to suit your personal style. This means that you can change its looks at any time by using any of the 16 included design covers. But this is only the beginning since you can also choose from different optional rings, additional design covers, ear and headband pads available on their website. Just choose your accessories and build your on style of headphones.
And for better convenience, the One Pro Plus comes with a built-in microphone and remote to let you answer your phone calls and also control all your media playback.
This product is provided with a flexible metal headband, it features rugged metal yokes and you can replace all parts even years after purchase. Talk about piece of mind!
It seems that Beyerdynamics have thought of everything when designing this product. You are provided with everything you might need/expect and its price looks pretty impressive for a product with that many options. What do you think?
Check out the following features and specifications for more information.
FEATURES:
- Sound Slider - variable bass reflex system.
- Custom Style - versatile changeable design.
- Custom Cable - detachable cable.
- Soft ear and headband pads ensure high wearing comfort.
- Handcrafted made in Germany.
SUPPLIED ACCESSORIES:
- 1.3 m headset cable with one-button remote.
- 1.5 m standard cable with screw-on type.
- 1/4" adapter (6.35 mm).
- 16 design cover.
- Hexagon screwdriver to change design cover.
SPECIFICATIONS:
- Transmission type: Wired
- Design (operating principle): Closed
- Impedance: 16 Ohms
- Frequency response: 5 Hz - 35,000 Hz
- Nominal sound pressure level: 96 dB
- Remote: 1-button remote
- Construction: Circumaural (around the ear)
- Cable & plug: Detachable cable – various connectors available.
- TRRS standard: CTIA
- Weight without packaging: 290g
Price: $229.00/each.
