Between 3: Denon X4000, Onkyo NR818, & Integra DHC-80.2
ErinH
ErinH
Cross posted elsewhere, but I know there are a few here with direct experience with some of these so if you don't mind....
I've been debating the past couple weeks about which route to go with my setup.
I'm currently trying to decide between these three:
  1. Denon AVR-X4000[/URL], refurbed @ $799 from Accessories4Less
  2. Onkyo TX-NR818[/URL], BNIB @ $699.
  3. Integra DHC-80.2 PreAmp[/URL], b-stock @ $960 from a local dealer. I have seen some used ones in the $800 ball park on e-Bay.
These share a lot of similarities, but have some differences. Mostly, though, the only ones that stand out for me are:
  • The x4000 & DHC-80.2 have SubEQ. which would bode well for multiple subs arranged symmetrically down to 4 (ie; 2 in front, 2 in rear). However, regardless of what setup I choose, I will absolutely be using an external DSP to control subwoofer(s) as I plan to add up to 4 at some point down the line. So, while the SubEQ is awesome, it's not a necessity.
  • The Denon also has Airplay which is a nice feature but not a necessity as I have an AppleTV.
  • Quality: The Denon is a refurb, where the Onkyo is brand new and has a 2 year warranty. On the flip side, I've also read numerous reviews on forums and Amazon regarding FW update that have caused issues for people's NR818... and some of those complaints were pretty loud. And, it seems to me the Onkyo may have better build quality (simply judging by photos, which may be incorrect). I've yet to hear anything bad about the Integra.
What I like about the Integra is that it's a pre-amp: it's pretty much built for my job. However, the only real feature it has that the x4000 doesn't have is Balanced pre-outs. It does have 9.2 channels, but I'm not too concerned about that in this moment; maybe in a couple years but by then I figure I'll have upraded anyway. The big downside is I can't do anything with it until I acquire all the amplifiers. Whereas, with the Denon and Onkyo, I can grow out of them and in to external amps.
Note: I'm going to be using all external amplifiers at some point down the line for my HT so the power ratings aren't terribly important to me. It would be a simple 5.2 setup for now, and possibly expand to 7.2 down the line. I've already ordered a Crown XLS1500 and will use another 2 to round things out for the center, and side surrounds.
I need a 2nd zone for outside. It would be nice to not have to purchase an external amp for this and just power the outdoor speakers from the AVR's amplifier. Not sure if I can run 7 channels in the HT and still run a 2nd zone or not, though???
I'm curious what your guys' opinion is regarding the purchase of these items. They're all pretty close to me... and I can make a legitimate case for any of them. I'm personally leaning toward the Onkyo simply because of it's price and BNIB nature, though I've never had a problem with buying used. Plus, I could take that extra $100 and put it toward an amp or AppleTV, etc. But I can almost talk myself in to the Integra as well. Additonally, the Onkyo site has me thinking the output voltage of the pre-amps is 2.8vRMS (they have a spec'd MAX rating of 4v). And buying from Crutchfield allows me to the opportunity to buy it and try it.
I think if the Integra were in the $700 range, it wouldn't be a question. But, that extra, extra cost is tough to deal with when I'm already on a budget. The difference in that vs the Onkyo in price would pay for an additional amp. I'm just not seeing the huge benefit other than in XLR pre-outs, since the SubEQ is of no special use to me (I already have a separate DSP for that task). What am I missing?
Having said all of that, I'm still not 100% sure on which way to go.
(I did see the 'Tale of Two Receivers' thread but didn't see a concise winner since his dealt with a faulty 818 refurb).
Thanks in advance and sorry for any rambling I've done. I tried to lay it out well but know it may be a bit scatter brained since it's 6am. ;)
- Erin
ReUpRo
Re: Between 3: Denon X4000, Onkyo NR818, & Integra DHC-80.2
You can see my comparison of the X4000 and NR818 in the forum member reviews section.
TL; DR:
X4000 and NR818 are the cheapest receivers with XT32 and pre-outs. Onkyo doesn't have SubEq (as you mentioned).
Onkyo has beefier amp section and certified for 4 Ohm speakers.
The previous gen Onkyo receivers had high failure rates due to poor heat management. That seems to have been fixed with the 818 gen. Has it improved reliability, only time will tell. That said, it still runs much hotter than the Denon.
The Denon has more Zone flexibility than the Onkyo.
Personally, I would not buy Onkyo or any refurbished items. There are deals to be had. Sent you a PM. :D
ErinH
ErinH
TL; DR:
Thanks for the feedback, guys.
I had read some issues with the Onkyo, which was a bit of a concern for me. Saw a lot of folks on Amazon griping about a FW update royally hosing them. I was leaning a bit toward the DenonX4000 but the price of it was just a touch higher than I really wanted to spend.
About 30 minutes after posting this thread, I saw CF had an open-box sale on the 818 so I went ahead and pulled the trigger. With their return policy, I figure it's an easy way to try it out and if I don't like it, I can send it back (or pass the deal on to someone on the forum). In all actuality, I'd like to go with a pre/pro but the cost is hard to justify when some of these AVRs do so dang much.
Still looking at options, though, in case the 818 isn't necessarily my cup of tea.
ReUpRo
I'm pretty familiar with the NR818. Feel free to PM me if you have any questions on setting it up.
Lulimet
Lulimet
I'd go with the X4000 too. Look around and see if you can find a deal on it. The refurb only has 1 year warranty while a new one has 2 or 3 (can't remember at the moment)
afterlife2
afterlife2
I love Onkyo and luckily never had a problem cause I kept mine cool with a laptop fan and ten inches of space, but the Denon seems like a better choice because of the sub eq.
ErinH
ErinH
Don't know if you guys saw my comment above but I picked up the 818 yesterday. I'll try to remember to update this thread with my results.
