Putting together a budget 2 channel system for audio only in my living room...can this deal be beat?
B BikeProf Enthusiast Jun 15, 2011 #1 Putting together a budget 2 channel system for audio only in my living room...can this deal be beat?
BoredSysAdmin Audioholic Slumlord Jun 15, 2011 #2 BikeProf said: Putting together a budget 2 channel system for audio only in my living room...can this deal be beat? Click to expand... yes and easily: http://www.amazon.com/Infinity-Primus-P362-Floor-Individually/dp/B000LKC372/ref=sr_1_1?ie=UTF8&s=electronics&qid=1308146940&sr=1-1
BoredSysAdmin Audioholic Slumlord Jun 15, 2011 #3 Or if you don't mind using your hands for 30mins or so: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-702 This is half price of Polks, literally and probably twice better than them
jinjuku Moderator Jun 15, 2011 #4 BikeProf said: Putting together a budget 2 channel system for audio only in my living room...can this deal be beat? Click to expand... Is that for the pair? If individually then there are better options. I generally only have people hop on the Monitor 70's when Newegg is blowing them out plus the free shipping.
its phillip Audioholic Ninja Jun 15, 2011 #5 Energy CF-70s go on sale every once in awhile for $199/ea...I've not heard that particular model, but I do like Energy speakers and the normal price is $499/ea.
B BikeProf Enthusiast Jun 15, 2011 #6 jinjuku said: Is that for the pair? If individually then there are better options. I generally only have people hop on the Monitor 70's when Newegg is blowing them out plus the free shipping. Click to expand... Good catch, right now, that is just for one, making in $400/pair...
jinjuku Moderator Jun 15, 2011 #7 BikeProf said: Good catch, right now, that is just for one, making in $400/pair... Click to expand... Yep, there are better deals out there for the $$. What City do you live in/near?
B BikeProf Enthusiast Jun 15, 2011 #8 jinjuku said: Yep, there are better deals out there for the $$. What City do you live in/near? Click to expand... about 2.5 hours from Salt Lake and 3.5 from Boise they will be powered by an HK3490 and I have about $500 of so left in the budget
jinjuku Moderator Jun 15, 2011 #9 Any of these closer?: logan ogden-clearfield provo / orem salt lake city st george
jinjuku Moderator Jun 15, 2011 #10 THIS IS WHAT I AM TALKING ABOUT Yamaha RX-V2092 $75. If it's in good condition (most likely is with it being a high end purchase) it gives you around another $200 towards speakers..
BoredSysAdmin Audioholic Slumlord Jun 15, 2011 #11 BikeProf said: about 2.5 hours from Salt Lake and 3.5 from Boise they will be powered by an HK3490 and I have about $500 of so left in the budget Click to expand... This one should do the trick: http://boise.craigslist.org/ele/2435309598.html - I think you should be able to get it at $100 or less Save the money on the receiver - get better speakers.
BoredSysAdmin Audioholic Slumlord Jun 15, 2011 #12 jinjuku suggested a better deal than I did, but just in case if that one already sold....
B BikeProf Enthusiast Jun 15, 2011 #13 jinjuku said: Any of these closer?: logan ogden-clearfield Click to expand... yep, these...
jinjuku Moderator Jun 15, 2011 #14 BikeProf said: yep, these... Click to expand... Not really anything to see there. Find out where that Yamaha is and give the guy $50 for it and RUN with it. I would take it over the HK and use the $$ toward speakers. So recommendations for $700 worth of speakers are in order. Last edited: Jun 15, 2011
GranteedEV Audioholic Ninja Jun 15, 2011 #16 BoredSysAdmin said: Or if you don't mind using your hands for 30mins or so: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-702 This is half price of Polks, literally and probably twice better than them Click to expand... Agreed! I second this. Although granted, the raw MDF ain't much of a finish.
jinjuku Moderator Jun 15, 2011 #17 BikeProf said: thanks, I'm now on the speaker hunt Click to expand... You could post in the DIY section here, AVS, Home Theater Shack and see if there is a member there that could help you DIY. Just a thought. Depends on how far down the rabbit hole you want to chase. Check out Zaphaudio.com for starters. If not no worries. Good luck.
zieglj01 Audioholic Spartan Jun 15, 2011 #18 Spearit Sound has a pair of the NHT ST4, used. NHT ST4 tower speakers (List $1,000) $499/PR Used http://www.nhthifi.com/ST4 http://www.spearitsound.com/specials.htm#Speakers Last edited: Jun 15, 2011
S SafeandSound Enthusiast Jun 17, 2011 #19 Can they really sound good they are very low priced. I am sure you can get a bargain these days on stuff made in China but I do wonder what level of design and parts could have been applied at that price. cheers
AcuDefTechGuy Audioholic Jedi Jun 17, 2011 #20 BoredSysAdmin said: yes and easily: http://www.amazon.com/Infinity-Primus-P362-Floor-Individually/dp/B000LKC372/ref=sr_1_1?ie=UTF8&s=electronics&qid=1308146940&sr=1-1 Click to expand... Agree with this 100%. Add a great subwoofer, and you got yourself a title contender!!! Or I would get the NHT AbsoluteZero for $175 each + a great subwoofer.
