Hi All, My setup is as simple as can be. I have a Samsung LN46A550 and I'm currently using the TV speaker. (I'm waiting until I move to enhance my setup.)
I've noticed a slight issue with lip sync (Blu Ray and HD programming). I found the Audio Delay setting in the Service Menu of my TV (which was set to 36) and tried adjusting it based on lip movement, but have found it very difficult to get accurate.
What can I use to help me adjust the Audio Delay correctly? Is there a disc I can use, or are there any other methods I may find easier?
Thanks for your help,
Matt
