Haha yeah while changing the mantel would be nice, I think I'll stick with trying out EMP's center first and see how it goes!
Actually, when I just put out another thread on the Loudspeaker forum to see if anyone else had experience with the center speaker, krzywica responded back quickly. Here's what he wrote:
I think it was probably me that commented on the poor performance of the E5Ci. My issue was that the cabinet resonance was transferring to my TV stand and creating perceived distortion. This made the center sound terrible at reference volumes but fine at moderate ones. This should not be happening if the cabinet was designed properly I wouldn't think as the very small foam feet supplied with the speaker are inadequate to dampen the speaker and isolate it from the TV stand.
I remedied this by placing the speaker on a couple of large high density foam inserts that came with the packaging of another pair of speakers I have. I can take some pictures when I get home and post them.
In conclusion I am now very happy with the center and it performs flawlessly. Its a little more revealing than I would like as poorly mixed TV shows (Castle for instance) the dialoge can sound muddy and improperly weighted and unnatural. But for anything that has a half way decent quality recording it is awesome and I couldn't be happier with it.
I'm still learning how to use these forums, so I'm not too sure how to include a quote as you did above so I just copied what he said. But anyways, bottom line is, yeah with his response and the fact that I can try them out for 30 days, I think I'm going to go with it.
It may be a couple weeks before I actually get everything in and hooked up, but I will definitely post a thread with pics and review my thoughts.
