Hey guys,
I am looking to upgrade my PC speakers from my Logitech Z-2300 to some active studio monitors.
I have read that when using a line-out connection on the sound card, you can pick up interference, and will not be able to take advantage of high quality sources.
My motherboard has digital coaxial and digital optical outputs, so ideally I would like to use those, and ultimately play lossless music.
Most nearfield monitors only have RCA connections, and from what I have read, the common trend is to just buy a RCA to 3.5mm stereo jack and call it a day.
Is there a way I can utilize my digital coaxial output on my motherboard, and connect it to the RCA jacks on the studio monitors?
Would I need a digital-to-analog converter between the two for that to work?
What kind of quality difference does a DAC create should I need to go that route?
Will using an RCA connection provide less interference than a stereo jack; if I am going to gain no quality benefits with RCA, would it still be preferred over the stereo jack?
Thanks for any and all input
