Best use of external amps with Denon AVR
jbrandoff
If I run a 7.1.4 setup with a denon x3600/3700/4700, am I better off running only the LF/RF to external amp and use all 9 amps in the receiver for everything else (including center), or will there be a benefit to sending center channel to external amp as well, thus utilizing only 8 of the 9 internal amps (I know it can’t be shut off, but is there a benefit to not using it)? I have a monolith x7 with at least three extra channels to use. Are there benefits to using less internal amps and more external? I haven’t decided yet which avr I’m buying but likely choosing among the three listed above.
Begs the question if you even need an external amp in the first place :) You don't provide much info to go on....
jbrandoff
I believe that since I am running an 11 channel setup (7.1.4) and there are only 9 amps in these receivers I will need at least two additional channels of amplification. Will therefore run fronts to external amp. I’m wondering if there’s benefit to running center as well?
jbrandoff
What speakers?
I haven’t committed to anything yet but leaning toward something from the Tekton lineup. Or perhaps GoldenEar. But not completely sure yet. Still working it all out in my head
Sorry, think I was switching from different question....center does get a lot of action so a 3ch amp may be better if your focus is movies vs music....
mazersteven
mazersteven
You need to figure that out first then figure out the Receiver/Amp
Verdinut
Verdinut
You might have trouble getting a Monolith 3 amp at present. Three Outlaw 2200 Monoblocks would definitely do the job. Here is a serious review of this monophonic amplifier:
EDIT: The Anthem MCA 325 is another option:
