Best Speakers for 500-700 bucks
K
Keeper420
I want to get a 7.1 surround sound set up for my new house. I plan on buying a yamaha rx-v1600 receiver. My new basement is 620 sq feet however, all this area will not be utilized exclusively for my Home Theater (i.e. I plan on having a bar and pool table that will not be separated from the "Theater" area.) I don't mind getting a 5.1 speaker setup now and adding 2 speakers later. What are your thoughts on this in my budget of 500-700 bucks. I was thinking either the Polk RM6900 or the JBL 300.7. However, when I looked on BHphoto they had a JBL E series Northridge 7.1 package for 700 bucks, which looked enticing. What do you guys think? Thanks:confused:
Take a look at this. Depending on your room and listening habits, you may want to step up to the PB-12NSD sub. The JBL and Polk packages don't even come close.
tdamocles
Looks like you would need mucho power to light the mains/center up......
They will enjoy more power if you have it, however despite the low sensitivity, they are adequately driven with a typical receiver. I heard them in a decent size room (~14x19) powered by a Sony ES receiver and they filled it fine.
billnchristy
Well, I posted one in the review section the night I got them, after a solid 4hrs of listening, but I will do another soon. Next month the HT will come upstairs for a bit while I demo. the basement for a true theatre. They will get a workout then.
I do only have a stereo pair though, but I would reccommend them to anyone, especially for the money. I am more impressed with them than the $1500 or so infinity mix i have downstairs.
Pianoman84d
The X-LS rock for HT!!!!!!!!!!!!!
How could they not, they do music so well. They really draw you in to the movie.
Pianoman84d
For HT or music?
For HT, almost any main speaker needs to be crossed over to a sub.
For music, I believe the review on audioholics was written without a sub engaged. Other than that I can't help you too much because I have mine crossed over at 80 in order to take the strain off my receiver. based on hearsay from others, they have good bass on their own.
Martiad3
biz97 said:
How do the XLS sound w/out a Sub?
If you're thinking about the X-LS without a Sub ( I presume for stereo music listening), think about the X-SLS. Basically a floorstanding X-LS. Lot's of good info in this thread at av123.com: http://av123forum.com/showthread.php?s=&threadid=13775&perpage=15&highlight=xsls&pagenumber=9. 3rd post from the bottom says that the X-SLS woofer will sound even better than the X-LS. All that for $100 more than the X-LS, even less of a difference if you need stands for the X-LS.
Just my thoughts...
edit: thought I'd throw in my thoughts for a 5.1: 2 pair of X-LS at @199 per pair, 1 X-CS @129 (comes out in September), then any sub to fill out the remaining budget (I don't know much of subs).
billnchristy
The XL-S Sans sub isnt too horrible. They certainly can convey the impression of bass without the feel and depth of a larger woofer. They put out more bass than my Infinity Reference 2000.4s by a large margain and those are floorstanders.
It is not earth shattering, house rocking bass mind you, but it certainly doesn't lack horribly.
Hope that helps?
Oh, I definitely wouldnt watch movies without one because they would probably be overwhelmed.
On music they have incredible control though, appearing more piston like than a resonating disk...very controlled.
