best speaker for Onkyo CS-210
modenar1
i have a mini Onkyo CS-210 system, which is rated at
Power Output (4 ohm, 1 kHz, FTC) 20 W/Ch
Dynamic Power* 4 ohm/8 ohm (front) 24 W/Ch/18 W/Ch
THD (Rated Power) 0.2 %
Frequency Response 10 Hz-50 kHz (+ 0 dB, - 3.0 dB)
Damping Factor (8 ohm) 25
S/N Ratio TAPE/LINE 100 dB (IHF-A)
the current speakers are
Speaker Type 2-Way, Bass Reflex
Drivers Woofer 4 13/16"" OMF Cone
Tweeter 7/8"" Balanced-Dome
Frequency Response 50 Hz-40 kHz
Crossover Frequency 7.5 kHz
Sensitivity 83 dB/W/m
Max. Power 70 W
Nominal Impedance 5 ohm
i wanted to what speakers can i hook up to this system to improve the sound, but at the same time i dont want to burn out the amplifier.
what specifications should i look for in a speaker. or what speakers would be recomended
all your feedback would be appreciated.
pearsall001
Wilson Audio Alexandria's. You'll love 'em!!! What's your budget?
pearsall001
Seth=L said:
I hope you are being sarcastic.:)
Ah! come on now. I'm just having a little fun with the guy. Apparently he hasn't learned anything from all the threads he has started. Maybe he'll actually look something up & figure something out for himself. Maybe he'll go to Best Buy & ask to listen to the Alexandria's, I'd like to be a fly on the wall for that conversation.
Wafflesomd
Wafflesomd
Everything from Wilson audio looks dumb to me. But that's just me. I'm more a phase plug, paradigm, yellow cones sorta guy :D
modenar1
i decided to go with the Athena B2.2 bookshelf speakers. i will let u guys know how it sounds once i get it and connect i to my system
