Best pre-amp (under $2000)?
starcraftbw
I am a newbie in audio world. I'd like to know what is the best 2-channel pre-amp for music only? I tried to search and read for days but I can't find it. I am sure all experts in here will be able to lead me to the right direction.
Thanks in advance,
PS: i just bought a marantz MM9360 power amp (6-channels + bridgable)... I can convert it to 3 channels. I also had Marantz receiver (SR-19) bought it used for 5.1 set up. Please help the noob
mike c
mike c
music only, is that 2 channel music?
Rotel RC1090
Parasound P3
use the rest of the money to add to your speaker budget
starcraftbw
Rotel RC1090
Parasound P3
cool, I'll read about these and make my choice.
thanks
mike c
mike c
there's a cheaper model of the rotel RC1070 - I think it's half the price (around 500bucks over here)
others would also suggest getting a decent AV receiver to act as your pre-amp. e.g. Yamaha Rx-v659, Rx-v2600, Rx-v2700 depending on your budget.
this will let you upgrade to a surround setup in the future.
highfihoney
highfihoney
You can get a whole lot better model preamp from buying used gear instead of new,go to audiogon & look in preamps.
http://www.audiogon.com/
Here is a link to an excellent & flexible 2 channel preamp,ive used c-38's alot over the years & their performance is hard to beat & in a 2 channel preamp its flexibility is even harder to beat,the c-38 has 3 amplifier outputs so in the future if you wish to add more amps & speakers or a processor its easy to do.
http://cls.audiogon.com/cgi-bin/cls.pl?preatran&1171243930
This preamp has a flaw in the glass face but a new face can be bought direct from mcintosh labs for about $150,ive done business with this guy before,his name is george & he has quality stuff.
Rob Babcock
Rob Babcock
Moderator
The three preamps that most intrigue me right now are the Modwright SW9SE , the Bat vk 3i and the Van Alstine Ultra EC or Transcendence 8. All are tubed or tube/ss hybrid and all are readily available new or used under $2k. I suppose many of you will ridicule me for my sentimental affection for tubes, but so long as they're used correctly tubed gear can be superb.:D
Rob Babcock
Rob Babcock
Moderator
BTW, plan on doing some real reading and research. For a budget of $2,000 you can get something truly outstanding- the sky is the limit at that price point!
starcraftbw
very good advices..... I'll do some reading today to see which of those fit best for my system. thanks guys..... i'll keep up the update. :) happy noob
twitch54
For under two grand my vote goes to Audio Research, you could by a new LS-16 for that money, with proessor out for your H/T set-up
mike c
mike c
is that 2k ONLY on the preamp or does that include the amp?
and 2 channel only right?
starcraftbw
^^^i bought a power amp already..... 2 channel preamp.....
mike c
mike c
ok then, 2k budget ... the sky is the limit! (up to 2000 dollars) :)
I wonder how much those classe preamps are ... why dont you check it out, I never bothered asking, because classe is way off my budget
wire
wire
Agreed
Man there are alot of choices of great equipment at that price range .
Ill add Sunfire Pre to the mix .
starcraftbw
the list:
Mcintosh C-38
Mcintosh C-41
Mcintosh C-45
Bat VK V3i
Krell krc-3
Mark levinson 38
Meridian G-02
hard to pick one.... i am leaning toward the Mcintosh... any suggestion?
wire
wire
starcraftbw said:
the list:
Mcintosh C-38
Mcintosh C-41
Mcintosh C-45
Bat VK V3i
Krell krc-3
Mark levinson 38
Meridian G-02
Nope
Looks like a pretty fine list , someone else here would have better input than me :) .
