Personally, I think the AKG K845BT's are the jam! They don't have active noise-cancellation, but they are closed back and thick (and constructed out of metal), so the sound leak on them is limited and the amount of outside noise you pick up is also minimum. (Plus, active noise cancellation makes me feel like I'm listening to music in a black hole, and I don't think I like it).
Hope this helps,
Homer
