Best Headphones for ~100
MrPirate2882
I'm looking for over the ear headphones, that has really good bass AND sound quality. I just bought some sennheiser HD555's and while the quality is amazing, the bass isn't. So i'm thinking of returning it to Amazon and trying to get something else. Any ideas?
If this helps at all, I listen to dubstep and other electronic music, as well as rap, and occasionally some metal
emorphien
emorphien
You might want to consider something like the Sony MDR-7506 (also known as the MDR-V6 if I am remembering correctly, identical aside from plug coating). I have these with the Beyer pads which are cloth and more comfortable in my opinion. They would come in under $100, probably around $80-90 depending on which version of the Sonys you get.
jamie2112
Sony MDR 7506 is my choice.............$89 some places and the BEST for anything close to that price........
MinusTheBear
MinusTheBear
For your bass void I would suggest the Audio Technica ATH-M50. If you want to spend just a bit more money even better the Shure SRH 840.
MrPirate2882
Those Audio-Technica's look pretty nice, but the 50 extra bucks does make me one to try and look for other options. Oh, I also don't want any sound leakage. It's really bad on my sennheiser's. Everyone can hear what I'm listening to.
MinusTheBear
MinusTheBear
Those Senns you have are open style headphones. Any open style headphone will leak outside noise in and the sound of the music will leak out. What you need are closed style headphones. The Sony MDR 7506, Audio Technica ATH-M50 and Shure SRH840 are closed models.
Another closed model I would recommend if you want to spend a bit more money is the AKG K271 MKII.
MrPirate2882
Oof. Those AKG are too expensive. I'm just going to be doing casual listening. No recording or anything... which is why I want to spend close to $100. I'm considering those Audio Technicas, though unless someone recommends something else. What I get also depends on how much money I get from my return to Amazon.
jinjuku
jinjuku
Moderator
I can personally 2nd the recommendation for the AudioTechnica ATH-M50. It seems that when it comes to headphones I always see Sennheiser and AKG but never see Audio-Technica or Grado mentioned. It's unfortunate.
I love my A/T's.
MinusTheBear
MinusTheBear
The AT M50 are a good choice. I think you will like them.
hatrack71
Did you post this on AK? I would say used STAX electrostatics.
