Best dampening material for in-wall/in-ceiling enclosures?
allargon
Should I use acoustic foam, composite material, thin rockwool, eDead (which seems to be like dynamat), dynamat, or something else? Of course, I'll adhere this to the 2x4's and the dry-wall/insulation behind the speaker.
I forgot to mention budget friendly--so best budget friendly but not super cheap like recycling shipping popcorn.
Thanks in advance.
lsiberian
lsiberian
Thanks in advance.
Rockwool is the cheap way.
Peel'n seal is a cheap version of dynamat but still expensive compared to rock wool.
Parts Express had Acousta-stuf on sale recently; $9 for a 1lb bag. I bought a bag because I have some speakers to build still...so I can't say how it performs.
They also carry something that looked like a copy of No-Rez for pretty cheap, though I can't recall what their version was called.
allargon
That No-rez stuff clone is the composite material I was talking about.
clone...
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=260-530
the real...
http://www.gr-research.com/index.asp?PageAction=VIEWPROD&ProdID=103
I figured those spray in a cans were lame. So, this is what is the better option for in-wall resonance control?
Rickster71
Rickster71
If it were me, and the stud cavity was opened up:
I'd use 'peel n seal' or a spray-on car undercoating(a few coats), then rock wool.
Unless the material is heavy and dense, you'd be surprised at how little effect it has.
