Best Bookshelfs for Under $300
Big_I
I am on a lowly student budget but I still splurge now and then. So I'm looking to pair my old Marantz 2230 with some halfway-decent bookshelf speakers for under $300. I know this is a home theater oriented forum but I really just listen to music.
These will need to go in my office which is a very small room (7'x11'). I don't want to mess with a sub (my receiver is so oldschool I'm not even sure that would work), so hopefully they could have some decent bass output.
Any input on this one?
gene
gene
Audioholics Master Chief
Administrator
In that price range, the Axiom M3s or the Infinity Beta 20s would likely be your best bets.
The CBM170SEs are a great choice also, though their bass is not quite as pronounced. They are very accurate and clean.
Accessories For Less has a Mordaunt Short sale going on now. The 902i are $350 with an additional 10% off: http://www.accessories4less.com/cgi-bin/item/MORDAV902ICLV Mordaunt Short is a sister company to Marantz. These are what I used to use (902) with my PM7200 and they are a solid performer.
AV123 has the no cost to you 30 day trial as well.
Epos ELS-3 would be worth a look as well, though they are 4 Ohm speakers. The Marantz should be able to handle them, but it is something to consider:
http://hcmaudio.com/comp.asp?compID=522 $296 Shipped.
John Bailey
Last I looked Saturday Audio had PSB B25's for $299 and Monitor Audio B2's for $279.
John
Joe Schmoe
Mirage Omni 150s are still available a Ultimate for $280/pr. They are absolutely stunning. In spite of being small for bookshelves, their bass output easily rivals that of my floorstanding Polk Monitor 50s. The omnipolar design provides a huge soundstage that will make your room seem much larger. To my ears, they could easily be worth $3000. Too bad you missed the half price sale.
3db
3db
I concur whole heartedly with Joe Bailey's recommendations. They are proably the best ones out of the ones recommended so far
Big_I
Re: Best BS<$300
Info overload!!! :D
So many of these speakers look great but I have to say that the Onix x-ls and the CBM-170 SE really catch my eye.
Thinking out loud here:
---If the Onix x-ls's sacrifice some linearity and gain some bass over the CBM-170, that might be an acceptable tradeoff for me (since I won't buy a sub).
---The x-ls's have paper cones... is that an issue?
---Some of these suggestions are sale priced speakers... that could translate to better quality (or not). Do these more expensive speakers (MS Avant 902i, PSB B25, MA B2) outperform the x-ls or cbm-170?
mazersteven
mazersteven
Just because a speaker cost more does not in any way mean it sounds better.
And there is no issue with paper speakers.
Big_I
Re:BS<$300: paper cones on x-ls encore
The X-LS have paper cones?:confused:
From av123.com: "Peerless India 6.5" curvilinear shaped treated paper cone woofer""tweeter is a Peerless India 1" treated fabric dome"
Sheep
Sheep
# Drivers: 1" Peerless India fabric dome and custom Peerless India 6.5" curvilinear shaped treated paper cone woofer with polymer chassis
You know with about 4 seconds of effort you could have answered that question.
SheepStar
mazersteven
mazersteven
SheepStar
And if he did that you wouldn't have been able to throw out a wise crack, and add to your post count. :eek:
Big_I
Re:BS<$300
Just because a speaker cost more does not in any way mean it sounds better. And there is no issue with paper speakers.
1. I agree
2. I have alot to learn but just thought I'd throw that out there. I've been rockin paper cones my whole life.
I'd love to hear more about the tradeoff between the x-ls encore and the CBM-170 SE from people who have listened to both.
