I hope you enjoy them...They're definitely some decent speakers, but they REALLY need the right room, both because they're bipolar and because of the metallic tweeter; they're just a naturally bright speaker.
I assume with that size of a room, you'll be able to get them plenty far away from a wall. I hope the room is carpeted? Good to see the ceiling is only 8'.
edit: Just found it on the site you posted:
"Class A/B operation for low distortion. 250W RMS @ 4ohm <0.1%THD, 150W RMS @ 8ohm<0.1% THD. "
So yea, less wattage, but typically more accurate response. BASH is, of course, built for the optimal balance between A/B and D (high power and accuracy), but isn't quite as good as either.
I assume you already know, but if not, here's a link explaining the benefits/drawbacks/working of BASH:
http://www.bashaudio.com/technologies.htm
