pjoseph
Looking at the back of this amp it looks like it has no RCA inputs.
I am using a Marantz Receiver which has a sub-output which is what I was going to use to send a signal to this amp since it is for a sub but I dont believe it will work?
Is there a way to connect to this amp using my Marantz Receiver?
thanks
F
fmw
Or 1/4" phono to RCA depending on the available connectors on the amp. If it is for a subwoofer, you probably want to bridge it. Just be sure you connect to the correct channel after hitting the bridge switch.
