I have the dual voice coil Kappa. I am in the middle of the simple slot port build, and it occured to me that the plate amp I currently have is not the best solution for this sub. So, I have a couple of questions for you.
Does anyone know of a deal to be had on a Behringer 15 or 2500 right now?
Does the Behringer have built in crossover abilities or do I need an EQ with it?
How do you hook up a dual voice coil speaker to any amplifier? (Does it need to be hooked up to both channels?)
Thanks guys for everything!
