i have an elite 54tx in an enclosed cabinet and would like to use my remote without opening the doors. the manual advises using an ir receiver (the remote sensor would then be mounted to the outside of the cabinet and there is a pin plug input on the amp rear panel ).they mentioned two supply companies (niles and xantech). I checked out their sites but had no idea about what I needed...does anyone have any recommendations or ideas...thanks
