Beeping sound from new subwoofer
Dolby atmaz
Hi, i just bought new speakers 5.1 and after using it about for 3 weeks it started to make strange beeping sound - subwoofer. I have harman kardon hkts 9/16 and amp is denon avr-d520bt. What is the reason of this sound? Its new, and it never been like this. Thank you
WineOfTheVeins
WineOfTheVeins
What do you mean by a beeping sound? When does it do it? Idling, while watching movies? What kind of hookups are you using?
everettT
everettT
Beeping is typically an indicator, but I havent seen that on a sub, unless its wireless.
Dolby atmaz
Same sound like in video. when i turn on my speakers and amp it starts sometimes during the movie, but i think its random. i will check what hookups im using. My subwoofer is not wireless.
Drunkpenguin
Ok, buzzing and beeping are 2 very different things lol. Sounds like a ground loop to me. Better cables can help sometimes. If you unplug the rca cables does the sound go away?
My living room sub suffers from this a little bit. What I did was turn the volume way up on the receiver which allowed me to turn the sub down enough that I could no longer hear it. My living room is not a critical listening space so this was easier than trying to track down the source problem which can be tough with these some times.
Dolby atmaz
hookups is red yellow white cables which goes to amp, dont know how they are called. I turn off sub then i turn it on and for some time the buzzing sound dissapears
OK disconnect the cable from receiver to sub. Does the buzz stop?
Yes, you have a ground loop.
No the sub power supply is shot. Actually that is what it sounds like to me.
Cause: - you bought absolute unabashed junk.
