Hello, in that setup menu before I got my sub I selected speaker presence and size with no sub and ran the test tone option, as far as adjusting the dB levels of individual speakers I was only able to lower the levels, no +dB only 0 dB or -dB, which I found to be odd, I left all levels at 0 and used the Panny 85 player with no sub. In the MCH mode in receiver I could not run any test tones with the receiver, so I just used the speaker xover and each speaker levels that I had selected in my original calibration with the SPL meter and sound quality was very good without sub. I have since added a sub in the BD player's 2 channel + 5.1 or 7.1 analog setup. What happened next was even more baffling, I ran the test tone generator in the player's menu and was still unable to increase the dB levels only -dB and it skipped the sub all together, it was not recognized, no xover setting either. I contacted Panasonic and this it what they said when I told them what was happening
uring the speaker test there will be no audio from the sub nor would you be able to increase the decibel of the individual speakers, this is normal, this is not a malfunction of the unit (DMP-BD85) as thats how the unit was designed, thank you for contacting Panasonic, end quote. In the MCH setting of my receiver I was able to adjust speaker levels, I just used the levels that I had previously set on the original calibration as test tones are not available in MCH operation. I have not tried playing a BD yet since integrating the sub. In the decoder section of the receiver's MCH option there is subwoofer sensitity adjustment, 0db, +5dB +10dB and +15dB, this option is only available in the MCH menu. I'm assuming since the player has no sub options except it's presence that I would have to add a LFE boost to the sub in the receiver's MCH subwoofer sensitivity option, what do you think? As far as the 2 channel downmix +5.1 and 7.1 analog setting, I'm using a 5.1 setup currently and chose the 7.1 option and selected no back surrounds in the presence option, right or wrong, your thoughts. Mark or anyone else who commented please tell me if I'm on the right track here, add the LFE boost in the receiver and using the right analog option, 2 channel downmix or 7.1 without the back surrounds? Thanks to all, I really appreciate your thoughts on this. Again thanks for listening.
Best regards, Jeff
