Battery Back up for DLP TV's
itschris
itschris
Moderator
I was just about to buy that Newport unit in the DEALS section, but then thought about the need for battery backup for the DLP TV I have. SAMs Club of all places has a pretty good deal on a small battery backp/surge protection unit for about $90 or so. I'm thinking that may be a better solution. It should certainly have enough juice to last a minute or two to cool the TV down and should be just as adequate as any other non-super expensive surge supression. Thoughts?
1
10010011
As long as you are not anal about it being a precise sine wave and are not expecting it to lift a thousand vales in your audio and make your DLP's picture become more 3D and make the blacker than blacks even more blacker than black.:rolleyes:
Cheaper UPS's often called "line interactive" just let the line voltage pass through them under normal conditions. Most do provide a level of surge protection on par with better rated surge suppressors.
Really as long as it is rated a high enough output power it should be fine for short term outages and cool down.
jostenmeat
Im using a Belkin for my PJ. Shortly after the purchase, there was a thread here talking about UPS's. TLS guy had a lot to say (he was in charge of his hospital, I think). Anyways, I believe it was an Audioholics mod, but there was a recommendation on APC as refurbished for about $70, IIRC.
If I did it all over again, I would've done that instead, saving close to $100. The Belkin looks nicer, perhaps, but its in a place where this does not matter much to me.
mr-ben
mr-ben
be careful
Two thoughts:
A $90 UPS probably outputs a square-wave, not a sine wave. This may or may not severely damage your TV. You should check what it outputs, and if it's a square wave check with the TV manufacturer to find if it's safe.
Make sure the UPS can sustain the power draw of the TV. A TV that uses 300 watts probably should have a UPS rated for 600VA or more. An undersized UPS is as useful as a power strip.
MDS
UPS runtime ratings are for half-load. So if it says 600 VA with a runtime of 10 minutes on battery, you will only get 10 minutes if all the connected equipment is drawing 300 VA or less.
itschris
itschris
Moderator
I guess nothings ever easy... Here is the one I was looking at. I don't see anything about square or sine waves though.
http://www.samsclub.com/shopping/navigate.do?dest=5&item=383091
It looks to be 750VA. I'm only looking for this thing to last long enought to turn my TV off which is about 1 minutes. I'm assuming I'll be around if the power goes out since the TV is never on unless someone's watching it.
MDS
From the listed specs: Voltage On Battery: 115 Vrms + 8% (step-approximated sine wave).
Any UPS that does not say 'online' or 'line interactive' uses a stepped aprroximation of a sine wave. It's not a perfectly smooth sine wave nor is it exactly a square wave. It won't hurt your TV.
A perfect sine wave output is only necessary if your TV is sensitive to poor power and you are a videophile that insists on watching your favorite movie despite the power being out.
itschris
itschris
Moderator
So I take it that while it's not a perfect solution, it's suitable in that it will help protect the system from surges and allow for some cool down time if the power cuts out.
