bass speaker hoohup
K
karls
I was given some expensive (to me ) equipment and cannot figure out what to do about the bass speaker. The speaker has two terminals for the cables but the amp (denon 3805) appears to have only one terminal for the bass. Any Ideas??
MDS
You can connect to either one of the inputs on the sub or you can buy a Y adapter to split the single cable from the receiver into two and then connect to both inputs of the sub. Using a Y adapter will boost the signal strength but is not absolutely necessary. Most sub manuals will say to use the Left input if you only use one.
