First and foremost I’m a newbie to the site so please forgive me for asking rookie questions. I own a Yamaha CX-A5100 processor and running a 5.2.0 setup and have been looking to improve my overall bass per ( Gene’s ) 5 steps to better bass! My subs are a Paradigm sub 12 and a Paradigm DSP 3200. According to Paradigm, they recommend running the perfect bass kit first ( which I have already done ) before running YPAO. I configured my fronts and center to small and surrounds to small 80hz with the parametric eq set to flat then ran YPAO. After I ran YPAO I made physical distance adjustments to the subs using a tape measure because they were off by 12ft or so. I measured the subs from side to side first because they sit one on each side of the outside of my front speakers then measured from each sub to the main listening area and entered those distances including the side by side distance. I then level matched all speakers and subs using an SPL meter at about 75db then increased the subs 4db in the Yamaha’s bass management per Gene’s recommendation. My subs and overall system sound so much better especially my surrounds. I suppose increasing the subs dB in the Yamaha’s bass management has created a little more overall headroom. Now finally here’s my question. Does anyone know what Yamaha’s YPAO sets the Hz in the subs bass management? I can’t seem to find it anywhere in manual speaker configuration. Also, since I’m running all my speakers at 80hz and trying to run my subs at 80 hz, do I need to make physical setting to my subs? They are both set at volume = halfway, cutoff = by bass, and phase alignment = 0.
