Bass management question.
Mike.A
OK, so I have read through the bass management section in the tips section on the main page. I think I have everything set up right, but I’m not sure. After all I’m still new. I have a Klipsch 5.1 setup, Klipsch RF-62’s for the fronts, Klipsch RC-52 for my center, and Klipsch RS-42’s for the surrounds. I used the my receivers auto-cal to get started with the speaker length and everything. Then from there I went in and changed some settings. I turned all five speakers to small, I think it had some on large but cant recall what ones. From there I set the crossovers all to 80.
The speaker response are:
RF-62 - 38Hz-23kHz +/-3dB
RC-52 - 67Hz-23kHz +/-3dB
RS-42 - 52Hz-23kHz +/-3dB
Now is this set up right, or am I doing something wrong. Maybe there is a more ideal crossover settings for some of the speakers? Any help would be much appreciated, as before you guys have helped me out tons, and just make all of this much more exciting :)
bandphan
bandphan
80 will be fine, you might want to lower it for the mains a bit (play around). What increments can you adjust?
