Bang&Olufson turntable - sound only on 1 channel
K
Kitamarie
I have a B & O turntable that when I plug it into the Phono plugs on my receiver I only hear sound from 1 speaker. Any ideas on how to fix this. The turntable is vintage but I would hate to get rid of it.
Start by reversing the cable going to the amp- if the sound moves to the other channel, the problem is in the turntable and if it remains in that one channel, it's in the receiver.
If you have a multi-meter, unplug the cables from the receiver and measure the resistance from each terminal in the end of the tonearm to the ends of the cables. If you see high resistance or no connection, you'll need to find out why. Could be as simple as bad RCA plugs but some B&O turntables had a cable with two RCA plugs on one end and a round 5-pin DIN plug on the other. You can measure the resistance from the pins in the DIN plug to the ends of the RCA cable. DIN plugs are available online.
If the receiver is the cause, rotate (or press the switch for) the source selector several times while a record is playing- it may come back, but that would likely be short-lived. It means the source selector switch needs to be cleaned. Caig DeOxid is a very good product that's widely available at a reasonable price. If you do this, clean all of the controls and switches.
If it doesn't come back so easily, carefully remove the cartridge from the end of the tonearm and look at the four pins- if they look clean, re-insert it and try playing an album- if it comes back, it may just be a matter of the cartridge pins and their terminals being oxidized. You can clean these with the Caig, too- remove the carridge, wet a cotton swab with the liquid and dab it in the end of the tonearm so some of it can enter the terminals, then re-insert the cartridge.
KenM10759
KenM10759
Good advice there.
At lot of times trouble with vintage turntables (we don't know the model number nor age of your B & O) can be related to mishandling of the tonearm, cartridge and/or stylus by the unknowing. With anything electrical, connections are the primary source of trouble, so checking and cleaning wire connections at the receiver, but especially at the back end of the cartridge (those 4 tiny wires with sockets to the pins of the cartridge) is an important step.
What model? Some have a mute circuit and if that has a problem, you can have this problem.
