Hostility
Hostility
ive read about people wanting to use bananna connectors, is it better to use those connectors or just the straight speaker wire?
Adam
Adam
Banana plugs are used for convenience, not performance. They will actually degrade the performance to some extent, but that extent is extremely small if you put the connectors on correctly.
I personally like how easy it is to disconnect the speaker wires in my system when I can just pull a banana plug out of a binding post rather than unscrew the post and pull out the wire. This is especially true if you are reaching behind a speaker or entertainment center.
Hostility
Hostility
well i dont unplug my speakers often enough to run out and buy them. just wondering if it was a performance thing or not, didnt think so, but sure does look a lot easier. thanks!
