I don't have any problems with them on the back of my Marantz. I recall one guy was concerned with his plugs/cables bending the binding posts and touching, whichever brand he was using. I played around with mine at the time and felt it required enough force to even get them close enough to touch that it wasn't really an issue: I keep my cables slack enough behind the AVR to prevent them pulling (of course no matter how much slack you leave, when it comes to pulling the AVR out, you
ALWAYS wish you had left yourself another 6"
*shrugs
Always, here, its a matter of preference.
The Monoprice option is very affordable.
The straight ones look nicer than the 90º ones with their tight rubber jacket, but behind my speakers, those 90º plugs are fantastic! I wanted to try the 90º plugs behind the AVR, but the straight ones there are better IMO, at least if there is a shelf involved, which there is in my case... maybe for a rack mount the 90º plugs would be fine.
