L
Lexterra
I was wondering if anyone had a solution to this problem. I've had a number of bad DVDs from Netflix, but as a patient person, I can send it back and report the problem. But the last bad DVD caused a bunch of loud pops while it went into freeze mode. 4 of the 5 channels on my JVC A/V receiver are shot now. An inspection of the DVD surface shows that it looks like someone took a brillo pad to it. Previous DVDs looked like Edward Scissorhands was the last renter.
I will be shopping for a new receiver anyway, but I don't want to blow the new one with another bad DVD. I presume that links from DVD players to receivers are digital (I know I've got an optical cable for my setup), so in-line filters won't work. But do the newer receivers have better protection from amp-draining pops? Or is a better DVD player the solution?
I've heard that some people have had a lot of bad luck with the poor quality of Netflix DVDs and that better players solved some of the problems. Thoughts?
