I have only noticed a couple members who have also taken the plunge and purchased the Boston AVR 7120 and was curious if anyone else has had any setup discrepancies with this receiver?
I finally found the time to begin installation of my new components and am having a he!! of a time trying to set these units up properly. This may be in part due to the little information the instruction manual provides. However, any advice would be most appreciated.
Last night I began running wire and placing speakers in the appropriate positions, but the end result was not what I desired. Right now I have only hooked up my two front old school Sony Towers and my Velodyne SPL1200 sub. I used quality 14 guage wire and AR banana plugs at all terminations except the sub, which is LFE connected. In the setup menu, which I was only able to access through my T.V. monitor OSD, I originally had my fronts set to large and the subwoofer to LFE. However, this setup did not allow any low frequencies to pass to the subwoofer and I had to adjust accordingly. Thus, I reset the fronts to small and set them at 80Hz. This made a significant difference in the sound output of the sub, especially when I place it in the corner of my 15x15 room. Unfortunately, with my fronts set to small, they now sound very flat. Is it possible to set my fronts to large and still pass the low frequencies to my subwoofer to allow for a warmer sound?
Furthermore, upon initial installation, I was unable to hear any output to any speaker unless I tweeked the volume to around -15db. From what I understand +20db is full volume and I was concerned that I did not hear a significant volume levels until I set it to 0db for music and around +4db for video output. I would think at these levels I could blow up my girlfriend's skirt and I was dissapointed to see that she was still fully clothed.
I guess my main concern is that I did not see the drastic difference that I expected between my 10 year old Technics receiver that used to only power my two Sony fronts. I am sure that this is a problem with how I am setting up my components, but I can't seem to figure out what I am doing wrong. I still have yet to wire my Phase Tech. Teatro 6.5 surrounds and Polk LSic center, and wanted to make sure I am not just making some newbie mistakes in the setup process.
Any advice would be most appreciated.
Thanks,
J.D.
