Vancouver said:
all good advice...anyone know the apx price difference in the CM2 and 705? I will find out soon enough i guess, but would be interested to know right now
MSRP for the CM 2 is $900/pair. The 705 lists for $1,500/pair.
I own a pair of 705s (as well as the floorstanding 703s, $3,000), and they are wonderful speakers. Keep in mind that the 700-series gets you the freestanding "tweeter on top" that defines B&W. On the other hand, I'll be the first to say that most people consider $1,500 to be serious coin for a bookshelf speaker, and the best value among B&W's lines is clearly the 600-series.
If I were you, I'd go down and demo a pair of CM 2s and see if they sound significantly better than 601s. I like the 601s, and I suspect the CM 2s' greatest advantage would be the real-wood cabinets and not much else. (Not that the "furniture factor" isn't important, because it is.)
Now that I think about it, I probably wouldn't take just one step up the B&W line, because I think the return would be marginal. On the other hand, if you can take two steps (to the 700-series), then it'd probably be worthwhile. But keep in mind that the $1,500 you drop for 705s could get you a pair of floorstanding 604s or CM 4s, so there's always a legitimate trade-off to consider.
