Hello all, this is my very first post and I've been using the site quite a bit as it has some great reviews and advice...
Before I get started let me detail my setup, which has a Denon AVR-3805 7.1 AV Receiver, (all speakers B&W) LCR600 as the centre, a pair of DM602 S3s for the front and the ASW675 subwoofer. The rears are DM601 S3s but are 11000 miles away and I'm bringing them back in Easter.
QED cabling has been used all around, and Airloc plugs on the receiver end for speaker termination. The subwoofer is hooked up via a QED MPSW cable connecting to the 'L' Line-In on the sub. Settings are, mode:auto, EQ:A, Filter:Out, Phase:0, and Volume:~20% of the way.
On the amp all speakers have been set as 'small', +3dB for the sub level and respective distances have been entered in metres.
The problem started the very evening I connected this when I decided to stream some online radio that really had zero bass. Afterwards the sub played dead and I had to power cycle (set to standby, then auto or via on/off switch) it and it came back on, which takes the receiver out of the question. Since then I've been playing with various settings on the receiver but these pretty much improved quality, not the duration of it working. I managed to get 1hr and 20mins max yesterday. Today I tried something different - POWER!. It was running off a Reillo 1KVA UPS which is connected to all the AV equipment: 42" Plasma, Mac mini, PS2, Satellite receiver, Router and switch (network stuff) and Airport Express + the Denon Receiver.
I decided to take the UPS out of the question and managed to get it to run for 1hr 40mins at which point the heatsink at the back was 'pretty warm'. I ran the 'Ultimate Subwoofer Test.mp3', which many of you may have tried continuously for that period.
Small note, if the receiver is set to standby while the sub is in its 'play dead' state after 5mins the sub it self will go into standby. If the receiver is started it'll work fine...
Right now I'm going to shift all the components onto a Patriot 600VA UPS and have the receiver alone on the 1kVA and have the subwoofer connected to the mains directly...
I don't want to write the subwoofer off as 'defective' as it performs great when it works...oh and I purchased this in England and carried it home with me this Christmas. The suitcase (a huge one) weighed 32kg and was fairly difficult to lug with me, and if I can help it don't want to have to go through it again...
Any advice would be greatly appreciated
--Mike
