Hello!
So im proud owner off B&W 684 S2 speakers along with B&W HTM62 S2 Centre Channel and B&W ASW610 subwoofer.Saving money for rears B&W 686 S2 to complete 5.1 system.
Anyways i have a little problem to determine what Low Pass Frequency should i set on my subwoofer.I have set in my AV receiver speakers to SMALL and set crossover to 80hz.Which i think its fine.But the sub also has Low pass frequency,and i dont know how would i set that.Mind,that i have sub set up as a extension to my mains not as a home theater sub.I enjoy listen to music on my fronts and i have set it up that way as a extension.That means i have LOW PASS on sub set to in.Problem is to determine what frequency should i set on LOW PASS Frequency setting.Curently i have it also on 80Hz.
B&W 684 S2 Specs.
Frequency range -6dB at 45Hz and 50kHz
Frequency response 72Hz - 22kHz ±3dB on reference axis
In the manual of subwoofer,says;
2-channel Audio Settings;
Set the VOLUME (LINE or SPEAKER) control initially to the 9 o’clock position. Set the LOW-PASS FILTER switch to IN. Set the EQ switch initially to position A. Set the PHASE switch initially to 0°. Set the LOW-PASS FREQ control to match the -6dB low frequency cut-off frequency of the satellite speakers. Note: Both -3dB and -6dB figures can be found in the specification of each B&W speaker model. If the satellite speaker manufacturer quotes only a -3dB frequency, the optimum setting for the LOW-PASS FREQ control should be between 0.6 and 0.9 times that figure. The more gradual the low frequency roll-off of the satellite speakers, the lower the frequency should be set. See the Fine Tuning section for more.
I have it set up like it says here.I know if i would use LOW-PASS filter to OUT.It would use sub amplifier and i could set Frequency to 140khz.But as a extension to mains you need to know what frequency to set.Having trouble understanding this line;
''Set the LOW-PASS FREQ control to match the -6dB low frequency cut-off frequency of the satellite speakers. Note: Both -3dB and -6dB figures can be found in the specification of each B&W speaker model. If the satellite speaker manufacturer quotes only a -3dB frequency, the optimum setting for the LOW-PASS FREQ control should be between 0.6 and 0.9 times that figure. The more gradual the low frequency roll-off of the satellite speakers, the lower the frequency should be set.''
If someone here has more knowledge of understanding this please help me.
