Alexhunter27
I am interested in purchasing the B&W 603 S3 floorstanders + center speaker and surrounds. My question is, Is it better to buy the wall-mount surrounds or 2 use the 601s as surround speakers? I am also considering buy the wharfedale Diamond 9s can anyone help with these choices?
Thanks
F
f0am
I just bought the B&W 603 s3's last month... I am very impressed. I am using the lcr60 for my center. They were worth every penny I spent on them IMO.
I am still using my canton mx's for my rear surround right now. Didn't have the money for the full set = P.
Let me know what you end up doing for your surrounds. That is my next purchase.
Bryguy
Bryguy
alexhunter27,
I have been using the B&W 604's for about a year and a half. I have them in a 12x15 foot room and still love them. I had looked at the PSB T65's and really liked them too (they were also magnetically shielded which the B&W's are not) but the local place that sold them would not allow full returns so if they didn't sound good in my room I was either stuck with them or a large store credit.
I "personally" don't think the B&W 700 series is worth the money though. There are much better speakers in that price range.
Bryguy
G
GreenJelly
I wouldnt buy the wall mounted versions unless you are happy with this nice feature. I would instead buy the 602's (or 602.5's) for the rears. However if space is limited then buy the wall mounted ones. The 602.5's are a better choice then the 602's because a good speaker stand would cost you the $100 difference.
N
Nick250
The 602 is a much more robust sounding speaker that the 602.5 to my ears. The 602.5 is just a 601 sitting on a box (internally). The 602.5 should really be called a 601.5. The nomenclature is misleading. But of course listen to yourself and draw your own conclusion. My personal opinion is that the 602 is an impressive value at it's price point.
G
GreenJelly
I agree and disagree... the 602.5 has a smaller driver, but I BELEIVE that the base is more defined then the 602... The 602 seems a bit loose. While the 602.5 seems to give that depth. They both are VERY sharp, and we are cutting hairs here...
The design is as you stated. Its a 601 type woofer in a larger enclosure. The 602 is a 603 type driver in a bookshelf system, and with no passive driver to push it harder. I hate speaker stands. I think they are expensive and they seem to make me uneasy about tipping them over...
As for my 603's (or for your 602.5 fans)... If I need to raise them up a bit... some nice fabric on a cinderblock will do the trick. Also Cinderblocks are the PERFECT speaker stand.
Anyways... if it comes down to price... buy the 601 rears and a 600 center. The center is so important, its worth every extra dollar you can put in it...
The 700 and 800 series are not my favorites either... I would quickly move to the Thiels at thoose price ranges, or onto some other speakers I havent heard:) I fear mixing 600's with 700's or 800's, but they have done allot to unify the tweaters in these speakers. So you may be able to pull it off.
Me Im stuck with the 603s2's and a 600 front (s3 of course). They mix well. You can find these speakers on Ebay and on audiogon often... save you some money. They resell for around 2/3rds the original cost... they really dont drop in value like many other brands (Thiels)
Mike
mike c
mike c
actually, the 602 is the smaller brother of the 604 ...
the 601 is the smaller brother of the 603...
the 602.5 is the middle child :)
I prefer the bigger driver of the 602 than the bigger enclosure of the 602.5 for better bass.
-0-
nick250,
I was misled by the 602.5 thing too, but I guess they based the numbering as the price went up.
nibhaz
nibhaz
Well, we've had a great discussion about the merits or lack there of, of B&W's numbering system but have we really answered the original posters question?
First off Alexhunter27, when you say wall mount are you referring to B&W's FPM series, the DS6 S3, or the DM600 S3?
Secondly, I would suggest any of the above options over the Wharfedale Diamond 9s in order to provide the benefit of voice matching. However my lack of experience with the FPMs means that my opinion is only based on the fact they are produced by the same manufacturer.
Thirdly, what will be the primary use of your system? This is important to know since it will determine the optimal type of speaker and the level of importance that should be given to voice matching.
mike53
Bryguy
I had listened to the 703 and 704 and was impressed. You mention "much better speakers in that price range"...any suggestions? Thanks.
G
GreenJelly
I LOVE the sound of the Thiels... Nothing is so warm and nice...
Its not always a favorite around these parts, for many people either love them or hate them. But they are Definately worth a take home audition, if you are a serious buyer. Remeber to ask about a power source, for these speakers have a very high impedence.
Thiel owners will be faceing some crisis in the future, for the 3 series seems like it will blow out the other high end series with cost. Their will be a major price gap between the 1 series, 2 series and 3 series.
B&W is probably a more accurate speaker, and would definately be better for a Home Theater setup. Their are some others, that I havent had a chance to listen to. It is outside my price range so I didnt do much listening in it.
I owned (and just sold) a pair of Thiel cs.5's, and they were amazing. They will be missed. I would have never sold them if I had a use for them. I went with the B&W 600 series with 5.1. The power requirements for Thiels made the 3.5 (which has a really low resell value) unaffordable to me. I miss the Thiels sound on many cd's. However on other CD's the B&W kick the #*$@ out of the Thiels cs.5's!
Bryguy
Bryguy
Mike,
GreenJelly already mentioned Thiels. Some others if you are looking at spending without a problem (703/704 level) try listening to the upper line of PSB, Von Schweikert, Totems, JM Labs to name a few. If you really are looking at this price range take a look at some of the speakers for sale on Audiogon or Audio Asylum to get some good ideas and then find a place to get a good listen.
Don't get me wrong, I love B&W's and if someone were to gift them to me I'd be overly enjoyed. But, once your talking about a couple of thousand for speakers you really do need to look and listen around.
Bryon
G
GreenJelly
[NEW INTRO]First of all... If your looking for LOUD, then you dont need to go much farther then your local Circuit City, and nothing in this post will help you. All of the speakers suggested here, and in this thread are VERY LOUD. Infact, we wont even talk about LOUD, because this level of performance is expected. What we want is sound quality. Sound Quality is the reproduction of sound that meets your unique requirements. These requirements are both Biological and Mental. Meaning that your ears and your head is different then EVERYONE elses, so you are the ONLY one to decide what is good and what is bad. The more money you spend, the more you tend to get a very exact reproduction of sound based on mechanical and human based methods of testing. That is assuming you dont buy snake oil.
[END INTRO]
The 600 series is one of the best sets at the price point. Very accurate speakers. Thiels are amazing for Accustical/classic speakers, nothing I have heard has played this type of music better. I havent listened to them in a (edit) full 5.1 theater setting. but I was not impressed with my CS.5's music ability on some types of Techno and Heavy Music. The other lines of Thiels will do much better at this. However if your primary enjoyment is not Accustical music (Tom Petty is AMAZING) then Thiels might not be for you. Thiels also have an amazing ability to play music at really low volumes while remaining constant and very enjoyable. (edit) I am disapointed in both of these areas when I compair my 603's with the Thiel CS.5! Thats not to say I think the 600 series is not as good as the Thiel CS.5's, for the B&W are simply different, and can reproduce a much wider range of music at a very high level of quality. Again, the higher priced Thiels perform MUCH better, but are also allot more money.
However, you also have to home audition at the Thiel price range. The dynamics of your listening area will greatly effect each speakers performance, and at the $2000+ (for a pair of speakers) price range requires additional attention to details (speaker placement, accustical room dinamics, etc)
The reason I say this is because these speakers are all about a great listening sound, however as you pass the $2000+ mark, you will find that you also pass the mark that allows you to place speakers anywhere. Simply put, you are facing the law of diminishing returns, and that law assumes you have a good listening environment, great power source, etc. If you dont, then your $10,000 speakers wont sound much better then the B&W 604's or Thiel CS.5's.
If you plan on spending a large amount of money on speakers, and you will have them hooked up to a TV, I would recommend a VERY good soundcard and a HTPC system. I am HAPPY to say this, but the days of component audio are over. The sound and features available from computers is simply breath taking and will match if not excede equipment costing $10,000.
Also, with HTPC you get the ability to start adding all of your audio (word deleted) controls (such as control over Light Sources, Project Screens, etc). Also with a HTPC you can Record TV, HDTV, and even Radio, and then Rewind and play back all three. Then with multiple HTPC's networked, you can share your shows and media with all of the devices around the house.
With a HTPC, those super high definition HDTV's with 1800 x XXXX definition can be used. Some of the great MPEG decriptors for Computers do image enhancement and will take advantage of that extra resolution. As new standards come out, HTPC's can simply be upgraded by removing cards, and adding new ones.
The only thing HTPC have yet to accomplish is the ability to have true Audio Video Passthrough, there-for a Pre-Amp or Audio Switch is needed if you plan on using a XBox or other time sensitive video source. HDMI is still not allowed to be inputted into computers, and your HD or BLUERAY DVD's wont be out for computer components for a few months too years.
If you have HDMI, I would recommend running the DTS/Dolby Digital (better known as SPDIF) through a switch to an amp, and then plugging the HDMI cable into your TV. If a HTPC meets all your needs, then I recommend you plug it right into an Amplifier, and forget about a AV Receiver or Pre-Amp.
There is allot more to this, then I am able to discuss in this thread. However at higher price ranges, amps become very important, and amps that are seperate from the PreAmp are a good choice.
You should also think about sound dampening materials or other attempts to prevent sound from bouncing off walls. Deep bass will rattle the windows so you must think about choosing windows that are more suitable for this application. Once again its based on your listening preference. I tend not to play music loud, so vibrations dont play a big roll.
If you have anything that makes background noise in the room, that you cant silence, then you just cannot justify the cost of high price speakers.
Speaker position is the single biggest factor in sound quality. Placing speakers against a wall is a no-no. Sitting with your back to a wall is bad, etc.. Small listening rooms are bad, big rooms are great and almost a necessity.
Just some things to consider... Also, dont buy into the expensive wire sales pitch. Buy the cheap stuff that people here can link you to. The sales man will do everything possible to sell you Expensive speaker wire... Simply refuse. If hes presistant, tell him that all evidence and studies have proved that Expensive Speaker Wire simply is not any better then regular copper wire. If he continues to push the topic, tell him that you will not shop with him if he continues to insist on high end speaker wire or if they wont support the speakers due to inexpensive speaker wire. I personally will tell a sales man, "To stop talking about speaker wire, or you will quickly find me walking out of the door"
Any recordings made before 1980 will have a natural hiss do to the age of the analog recordings used in the Digital -> Analog process. If you prefer old music, then expect this hiss. Check your recordings, if you want to listen to music with a hiss, then it doesnt matter much if you buy the B&W 600 serries or $100,000 speakers. Live recordings tend to contain feedback from the huge monitor speakers, again reducing the quality of the recording. Though sometimes you can find some amazing live recordings (Tool's discontiued CD/DVD combo has a few amazing live recordings). Distortion pedals give distortion. Again, it doesnt matter if you spend $1000 or $100,000. You will just have hiqher quality reproduction of distortion. Which supprisingly sounds like distortion.
My speakers will pick up the rumble of near by train tracks near one of the local radio station I listen to... It comes through the base, and cant be heard... but its there.
Mike
robot
robot
GreenJelly said:
Distortion pedals give distortion. Again, it doesnt matter if you spend $1000 or $100,000. You will just have hiqher reproduction of distortion. Which supprisingly sounds like distortion.
lol I like how you put that.
My Bloody Valentine has never sounded so good than on my new 603s :)
G
GreenJelly
FYI; I have edited my above post. I have had time to review it and decided it need to be better. I made allot of improvements to make it clear and better written.
If I get a chance I will work on it, and maybe turn it into a article.
Mike
mike53
Bryguy said:
Mike,
Bryon
Bryon,
I've listened to over a dozen speaker brands including Thiel, PSB, Spendor, JM Labs, B&W, Vandersteen and Quad in the price range of $1500 to $2500.
I've found the Thiel CS.5 and the B&W 704 best suited for my needs. My dealer said that once my electronics arrive I can Try out speakers before making a final decision. I'm just hoping that the B&W CM7s arrive in time.
Greenjelly,
I agree with your observation that the Thiel CS.5 sound good at lower volumes...I thought the same of the B&W 704. As for speakers costing more than $2000...that's a good point. I'm not one that always sits myself centered between the speakers to listen. Sometimes I move about the house - thats why such a large price range in the speakers I auditioned.
Thanks, guys, for all the input.
G
GreenJelly
The Thiel CS.7's (I think), and the CS.5's really didnt have the size to beat at the low end. So I would think you would want to step up to the Thiel 1.X or 2.X series.
Make sure you have 4 Ohm power if you want Thiels... and a strong amp. Though come to think of it both speakers need a strong amp. Both speakers would work great with 4 Ohm ratings though strong 8 Ohm amps exist in much greater numbers. This is one aspect that really gets them to shine. If your going with a high end Denon or Marantz then I would push you towards the B&W, for the Thiels will destroy these amps. I would push you towards a pre-amp from Denon or Marantz, and then a High Powered amp from some of the other wonderfull companies. This is at the least a $2000+ solution. However you will gain freedom to upgrade the Pre-Amp as HDMI comes out, and seperate Amps can produce amazing power.
Amps can last for decades... so its a long term solution. Often you can get them repaired with out spending allot of money, because the peaces that break in solid state amps are usually the inexpensive smaller transistors, resistors and compacitors. My father and I have fixed many Amps, and we never had a problem were the dead parts ended out to be more then $70.
Mike
mike53
GreenJelly said:
Make sure you have 4 Ohm power if you want Thiels... and a strong amp. If your going with a high end Denon or Marantz then I would push you towards the B&W, for the Thiels... I would push you towards a pre-amp from Denon or Marantz, and then a High Powered amp from some of the other wonderfull companies.
Mike
Thanks for pointing out the 4 Ohm factor...I hadn't give it a thought. I'm down-sizing from a pre-amp, amp, tuner and numerous other attached items. I decided on the Music Hall Maven reciever (100 watts) and 25.2 cd player.
I'll just be listening to vinyl and cds. I won't always be glued to a chair positioned exactly between the speakers...I'll be moving about the (large) room. The volume won't be eardrum shattering loud. I just want clarity and frequency response.
Alexhunter27
Thanks guys for all the input. As you can see I have not visited in a long time and have since been checking out other options. I have definitely decided against the 600 series and am now looking at either the 700 series or the axiom m60 Vassallo. I am a big fan of real wood veneer. Any comments would be appreciated
