thanks all.
aside from the sound level item i started this thread with (which may not be an issue at all), i have to say this amp performs very nicely. at the risk of using terms i may or may not be using in the correct context, here are some random brief comments: bass is solid and tight. music sounds very rich and clear. the presentation of most music is very powerful. the amp clearly gives me so much clarity and power that i often find myself listening at higher levels than previously and not realizing until i stop to think about it. ....sort of like driving a high end lexus -- it doesn't feel like you're going 85 until the officer tells you that's how fast you were going.
previously, i had 3 audiosource amp one's (run mono at 200 wpc) driving my front 3 speakers and my yamaha handling my back 2. in that prior setup, i sensed that the rear surround effects in movies lacked the same oomph that my front 3 speakers had. now, i have my B&K driving my main left/rights, one audiosource (mono at 200 wpc) driving my center, and the remaining two audiosources amps driving my rears. the surround effects are more pronounced and, thus, the movie experience is that much improved.
for $2100 i have 5 separate amp channels at or over 200 wpc. for 2 channel music, the B&K does a commendably job thus far. for both music and movies, separate amps have been a notable and enjoyable improvement for me. i sort of have the best of both worlds - a very good 2 channel amp for music. and, 5 amps for movies, without spending a fortune on name brnads all around. the audiosurce amps are priced right for those like me who watch the occasional movie, but enjoy heart pounding effects when i do crank up the flicks. one downside is i have 4 power cables for my separate amps, in addition to my receiver, and other components, tv, sub, etc.
reliability for the B&K is unknown at this point. i will keep a close and careful eye on it and will report any problems if they arise.
