Hey Guys lighten up on me a little would you. I bot the Paradigms because I believe these will be the last set of speakers that I will need to buy. Couldn't say that about the Axioms. I am building a system in the $5000 to $10000 range. I am looking unless technology busts me down to only buy things once. Just bot the ati at2500 to run these things. My system will not be the best but is will be more than enough. When I am done it will be:
Yamaha rx-v2400 Receiver $ 759.00
Paradigm Studio 100's $1700 ( with magnashields)
Paradigm CC570 $ 644
ATI AT2505 Adcom $ 1600
Still to purchase 470 ADP's (with stands, guessing $1000
Sunfire true woofer (Still to purchase $ 1100
Not sure on the DVD either the Yammy or the Denon (dvd-a and sacd) $800
Digital Flat Screen Not sure.
And good wires to run them $ 400
I think I am well within my budget and will probably not be needing to update for years to come. Will there or is there something better, yes, if you think for one minute the axioms will compare on quality "WRONG" as a value for the buck spent yes but if you feel that way why not just get a boom box with component video attachments to you RCA 25" TV. The problem with the axioms is that the statement will always be, Great sound for the money. Check the actual components that make the speakers up and you will understand the Paradigm difference. With the Paradigm the statement will be " Great sound period. Not to pop your bubble but if you are spending 800 and over why not get what you want instead of having to upgrade later. Take my advice friend, take the drive, make the trip and hear the Paradigms before you convince yourself the Axioms are similiarl They are simply not capable of matching the quality of the 100's. There is probably a reason that people such as myself pay more for better speakers. The age old statement still holds true "You get what you pay for." I am getting the system that I want ! Can you say the same? This may sound weird but I think I got more bang for my buck than you, so don't insult my purchase as some arogant spoil little brat who can afford to waste his money, not wise and prudent like you. I work hard for my money and have earned the right to have a better system if I want to, simply stated I think you both are trying to justify your cheaper purchases by agreeing that your purchases are more prudent than mine and therefore it is ok for you to buy a lesser quality. I don't begrudge you the systems of your choice, I take great offense in you treating like i am wasting money and stupid because I can afford a little better system than you. I not stupid or rich, just willing to pay for what I want.
