But for $300.00 savings, it is well worth it imo. So JcPanny, you saved me $'s with that advice. Would have never known about that. Thanks again.
QUOTE]
Lost,
So, do I get a cut?
Just kidding, enjoy the new speaker system and post your review when you have everything setup. Use that money you saved to get the sub you really wanted from SVS. Also, if you email SVS, they will honestly tell you what the best options are for your size room.
P.S. After you have completed your high end HT, you might have to change your screen name. You have seen the light.
