Methost
I'll be able to purchase my center next week. Do I need the VP125? or can I live with a VP100?
Currently I have M22Ti fronts and (4)Qs8 surrounds. Is the VP1050 too much to match up with the fronts that I have? Should I save the hundred bucks and just get the VP100? Has anyone heard both of them? Or have one of them that they can comment on?
Mort Corey
Have heard neither, but reviews I've read have indicated the VP150 is far better than the 100. With the Q8's and the MT22's I think I'd go for the larger center channel. Might want to pose the question on the Axiom forum too.
Mort
I haven't heard it either, but all reviews say the VP150 is the way to go.
mfree1138
I have the M22ti's in front and 1 pair of QS8's in back, with the EP350. I have the VP150, and I think it is a great mix with the rest. It has good off-axis dispersion and is very clear. I had to adjust it's location to a bit farther forward on the tv to get rid of a little boxiness in the sound, but other than that it sounds great. The sound is integrated on all sides.
aarond
have you thought about a third M22ti for the center?
i have a friend that put 3 M22tis across the front because he didn't like any of the axiom centers.
Methost
Did he mount it vertically or horizontally? Have you heard it? How does it sound?
