Awsome 2 channel CD - Jorane
mikey d
http://www.jorane.com/
the cd is called The you and the now
the website automatially loads alot of her music so you can check it out to see if you would even be interested.
It is basically Acoustic instraments with a female vocalist. her singing style varies throughout the cd from lounge singer style to really airy etheric sounding. mix that with alot of chello, upright bass and some other more exotic stringed and percussive instraments.
listening to this disk on my Axiom M80's only I would allmost swear the disc is more than 2 channel.
Please check the site out and order the cd if you even remotely like it. I think you will be pleased and leave your comments on this post. Id like to see what others think.
masak_aer
masak_aer
Very interesting...I might check it out later.
Buckeyefan 1
Buckeyefan 1
The audio quality over the pc is horrible (very sibilant, at least here). Her voice sounds like a mix between Madonna and Celine. Depending on the master recording, it appears to be a nice test for your audio system.
Sheep
Sheep
Thats because its your PC speakers. They stink. Every song I send you sounds sibilant. Boo you.
SheepStar
Buckeyefan 1
Buckeyefan 1
SheepStar
Wrong, there's 4000 songs on this hard drive. Most sound fine, and can be eq'd to get rid of the sibilance. A bad sampling rate is a bad sampling rate.
STRONGBADF1
STRONGBADF1
Nice find!
My old Altec Lansing PC speakers are so laid back it sounds pretty good but no detail...Her voice sounds alot like like Jewel to me. The music sounds cool and easy to listen to. (A nice change from my usual diet of hard rock/metal/prog.rock)
I like it,
SBF1
