I got this to work..
Brandon1123 said:
Have any body successed with the AVR-4306 connect to PC at all? I've been trying and trying but never got it.
My PC is running Windows Media Center SP2, Windows Media Player 11.
If whoever made it works, please show us. Thanks!
I got this to work......
First, make sure your AVR is truly on the network. If you can download the internet radio station list this is a good sign.
On your XP Machine fire up WMP 11 – Tools options -> Library Tab, Select Configure Sharing
Click settings button under sharing
Share media as : this is the name you want to advertise on the network (i.e. My MP3s)
Make sure music is selected from media types
Select the checkbox Allow new devices and computers automatically (you can lock it down to the Denon later if you wish)
Make sure you have some MP3s in your library
On the Denon change the Aux source to Aux/Net
A screen should come up showing internet radio and favorites. If you havn’t downloaded the internet radio list it may ask you to do so.
Normally this screen should show Network audio with favorites, internet radio, and also should display your PC host where you shared the files. Mine takes about 10 seconds to show up some times. I am using a wreless bridge so mine is a little pokey.
If it doesn’t show up then your Denon is not seeing your XP machine on the network. Try turning off the Windows firewall momentarily on the XP machine and see if that fixes it.
Also, I found out the MP3s in the WMP library must be on the same PC where WMP is running and not on a connected network drive if you have more than one PC and sharing drives.
If all this doesn’t work lemme know. You may have to PM me because the subscription alerts in these forums don’t work for me.
Hope this helps,
Tim
