AVR Pre with ATI amp. Need help
ematthews
ematthews
This may sound dumb but I need the correct answer on this. I am looking at a Marantz Slim line to power a small 3.1 set up. The AVR is the NR1506.. Am I able to use the pre out hook up to run my RBH SX-6300R right and left channel and use the AVR to power the center channel? I was sure. I don't think the Marantz AVR with 50watts will be enough to drive the 88db sen RBH to higher volumes..
Yes. Preouts for that one are front L&R only (besides sub) so that's the only choice.
ematthews
ematthews
Then this will be perfect. So I will use the Marantz to power the center RBH and use my ATI amp to power left and right. Thanks
