AVR for old speakers?
Beginner 1960
I have a old pair of DCM TF600 sen. 92db rec. power 10 to 250 watts 6ohm frequence range 30Hz to 20kHz Have been useing a old sansui RZ-7500AV receiver. Was looking to up grade my receiver wanting to know what would be a good fit for the 600s till i can up grade them? They cliped with the sansui when played at hi vol. the receiver is a 100 watt per channel at 8ohms. it was set to 6ohms to match the speakers. any help and input would be welcome thanks!!!!:confused:
Beginner 1960
more info for above? will be useing for music and ht when i can aford it.in a 20x30 room buget between 500-800 thanks agian:)
mike c
mike c
a reliable pro amp would be best ... does your receiver have pre-outs for the external amp?
Beginner 1960
yes it does but all the jacks are rca I need some hdmi hook ups:)
mike c
mike c
yes, you can get an HDMI receiver if you want, but get a receiver with pre-outs so you can use an external amp for whatever speaker you purchase :)
markw
How loud do you play that system?
92 decibles is a pretty high sensitivity speaker and it shouldn't take a whole lot of watts to drive it to deafening levels.
Just because a speaker can absorb gobs of power without the voice coils catching fire and ripping out and throwing the cone across the room doesn't necessarially mean it will sound good while doing so.
Beginner 1960
I don't lisen to it very loud very much any more maybe20 or more years ago but still like to crank it up every once in a while. going to try to up grade speaker some time this spring(income tax time) Just wanting to get some thing hooked up to the hdtv.also have my 1st subwuf on the way hope it gets here tommorow! would a yam 663 be a good one ? saw a a post where they thought they were down gradeing the amp in it? thank for ur help and time
Beginner 1960
can get a yamaha rx-v663 499$ or a denon arv-988 540$ would ether be good for what i want? whice would be the better deal?:confused:
