AVID Ingenium Turntable Review
gene
gene
Audioholics Master Chief
Administrator
The AVID Ingenium turntable is a remarkable blend of minimalist design and high-fidelity performance. Priced between $2,000 and $2,700, it features a belt-drive system supporting 33.3 and 45 RPM speeds, a 2.5 kg platter, and an inverted stainless steel bearing with a tungsten carbide/sapphire thrust point. The Ingenium's design includes a cork-and-rubber mat for enhanced isolation, a detached motor to minimize vibrations, and feet made from a composite blend of foam and Sorbothane for exceptional isolation. While it boasts a compact and visually appealing design, some users may find the lack of adjustable isolation feet and manual speed adjustment less convenient. Overall, the Ingenium offers a compelling package for audiophiles seeking quality and aesthetics.
Our review discusses the set up process, the quality of isolation and most importantly how it sounds.
Read: Ingenium Turntable Review
