DARK_AUDIO
DARK_AUDIO
Hi all,
How do I edit/add a custom Avatar.. I went to my Control panel & clicked Edit Avatar, here is what I get:
Avatars are small graphics that are displayed under your username whenever you post.
Do not use an avatar
Note: if you have a custom avatar selecting this option will delete it.
The little dot in front of "Do not use an avatar" is selected & I see nowhere to add/edit avatar!?
Thanks, Phil B.
Matt34
Matt34
Moderator
Hi all,
Thanks, Phil B.
You have to uncheck the "Do not use an avatar" circle to add and avatar. Then go below and upload your picture.
DARK_AUDIO
DARK_AUDIO
Matt34,
For some reason I can't "untick" the button.. I'm using Firefox 3.6.15 w/all add-on's disabled, I even tried IE with no luck!?
It's not that big of a deal.. I'll see if I can get it to work later.
Thanks, Phil B.
BMXTRIX
BMXTRIX
It may be one of those things which are disabled until you have a certain number of posts. Likely 10.
